LS6 Manifold with 85mm
Old 05-17-2012, 09:10 PM
ls1sickandtwisted's Avatar
Default LS6 Manifold with 85mm
As anyone done this befre or is possible to carefully sand the snout to 85mm to put a bigger TB
Old 05-17-2012, 10:13 PM
Just asking cus I have a good deal offered on a 85mm TB and 85maf that i can buy I just dnt want to buy it and not be able to use it in the LS6 if I cant sand the snout to 85mm
Old 05-19-2012, 03:43 PM
crainholio's Avatar
85mm - 78mm = 7mm. An awful lot of circumference to try and create by hand sanding. Is your hand calibrated accurately enough to get it perfectly circular?
Old 05-19-2012, 10:27 PM
moeZ28's Avatar
You would have to make the opening 3.5mm wider all the way around. That is quite a bit of material.
Old 05-19-2012, 10:29 PM
Blk98Vert's Avatar
Yep, my friend has it done to his
