ARP STUDS in block necessary to remove?
Old 05-18-2012, 04:03 PM
LSXFEIN's Avatar
Question ARP STUDS in block necessary to remove?
hey guys im getting my heads done still have the arp heads studs on the block is it necessary to removing to clean the threads and holes out of any debri? thanks for any help
Old 05-18-2012, 04:39 PM
LSXFEIN's Avatar
bump......
Old 05-18-2012, 05:18 PM
joecar's Avatar
There would be no debris in the holes since they're occupied by the studs...
and studs eliminate this problem anyway (since stud stays stationary in hole).
Old 05-18-2012, 11:12 PM
LSXFEIN's Avatar
Default thanks
thank you sir!!
Old 05-18-2012, 11:20 PM
Burken01's Avatar
you should be fine... I did the same thing, i took my heads off to get machined and wrapped my shortblock up with the studs still in... just checked it the other day to add some oil to the cylinders and everything looks perfect still..
Old 05-19-2012, 12:18 AM
LSXFEIN's Avatar
Default nice
thanks man, im just worried about torquing them down too much if the studs where to tight you know?
