sikfuk
05-21-2012, 08:51 PM
Selling this 2000 slp camaro ss 6 speed car. Car has 83,000 original miles on it at this time and is a clean title. Car is in very nice shape but does show some normal signs for its age, on a scale 1-10 i give it an overall 8.5. The clear on the hood and the rear spoiler have some clear peeling and there is a small spot on the corner of the hood that has an imperfection, all in all these are things that are minor and are really not bothersome unless you are showing the car for points.mechanically perfect except once in a while it will pop out of reverse, only happens sometimes, just put it back in and us fine, every other gear is perfect Car has a new jvc cd player with remote, and new speakers. Power windows,locks gray cloth interior,t tops tinted windows and ice cold a/c
mods: Engine: 2004 z06 cam and valve springs, new timing chain,oil pump and pushrods. New ac delco iridium plugs, msd wires, fresh oil change mobil1 syn oil .hollowed cats and slp y pipe,full borla stainless exhaust, sounds very nice maf screen delete, slp air lid and smooth bellow. Car was professionally tuned with hp tuners with a very aggressive tune. Runs very strong and all the emission monitors were turned off so emission test is a breeze.
Mcleod monster clutch,adjustable master,new mcleod slave b&m short throw with factory hurst knob, aluminum driveshaft
moser 12 bolt rear end with moser axles,3.73 gear,t/a girdle cover.
Suspension: Front qa1 fully adj coil over suspension, bmr drag front sway bar with new links and bushings, rear qa1 fully adj shocks with eibach sportline springs,bmr panhard bar, adj bmr lower control arms, short fully adj spohn torque arm going to a bmr weld in torque arm crossmember that is welded to the bmr weld in frame ties. This car handles awesome. Stock chrome ss 10 spoke wheels with brand new rikken raptors in the front and brand new nitto 555 in the rear all tires less than 500 miles. I am asking 12,400 for the car, it is not perfect but is a very very nice car, i will entertain trades for gsxr 1000's, hayabusa's with cash on your end. Call or text anytime 219 512 2739, don.
