gold/copper dust on new rebuilt
Old 05-24-2012, 03:24 PM
simpleboy77's Avatar
Default gold/copper dust on new rebuilt
Need some input on this.
If I have a gold/copper dust in my oil filter, what is it ? Should I reopen the block and check or run thicker oil ? Right now i'm on regular 10w30 oil
Engine have arround 500 miles. On cold start, I have 40psi no noise and when hot, I have 10psi at iddle and some valvetrain noise. Have 20psi when i'm at 5000rpm
Machine shop is out of business.
Engine is a 346/LS6 whit forged internal.
Old 05-24-2012, 03:26 PM
03Sssnake's Avatar
I would check the motor 1st. Could be a few things, maybe bearings...
Old 05-24-2012, 03:50 PM
Starkey's Avatar
Low oil pressure and gold dust in oil filter doesn't sound like a very great combo. My old TBI 350 did the same thing, no noise, ran good, just no oil pressure. Turned out to be a spun main bearing.
Old 05-24-2012, 03:56 PM
Redbull87's Avatar
That oil pressure at idle and at 5000rpm is too low.During the rebuild I hope you replace the oil pump and timing chain? That valvetrain noise is very bad for the lack of oil uptop.I wouldnt suggest running the motor any longer.I get 55psi on cold start up,60psi when im on it,39psi hot at idle on my cammed motor with stock pump as a comparison.
Old 05-24-2012, 05:04 PM
Wow, so there is something wrong on this built Oil pump is a ported LS6 and new timing chain. I got 60psi on cold at 5k rpm. I was hopping for the ''O'' ring at the pump was the trouble but the gold/copper dust tell something else.
Old 05-24-2012, 06:56 PM
Old Geezer's Avatar
copper color material could be the thrust surface going away. Check crank end play....
Given the psi U R reporting, I'm with the other posters, shut it down, and take it apart...
Old 05-24-2012, 07:08 PM
NVR_SPDS's Avatar
Its definitly time for a teardown!! I would assume you cut open the filter, or did you just find the particles while draining?
Old 05-25-2012, 07:09 AM
I cut open the filter. Did not drain the oil since I change it 200miles ago. I did alot of search here and that why I remove the filter first and cut it.
Always go the cheaper way first and move on to other cheaper possibility
Old 05-25-2012, 08:16 AM
Gunslinger09's Avatar
That sounds like you are down into the bearings somewhere. Crack it open now so you can save it, otherwise you are going to be buying a new rotating assembly. You know now why the machine shop is out of business.
Old 05-25-2012, 08:31 AM
ATwelveSec02Z28's Avatar
95% Chance you ate a bearing somewhere. Thurst, rods or mains are all possible. Could be from any number of reason, clearances too loose or tight, problems priming the oiling systems on initial start up, etc.
Youre getting loud valve train noise because where ever the bearings are damaged at, the clearances are high, oil is flowing right past and not getting to the lifters.
Old 05-25-2012, 01:31 PM
BadAndy's Avatar
You get any kind of warranty from the shop? I know you said they're out of business, but just because the shop is closed doesn't mean the business itself is dissolved.
Old 05-26-2012, 10:32 AM
Its a 1 owner shop. Place is empty.
I will open it to see what went wrong.
Old 05-26-2012, 02:52 PM
SmallBlock 383's Avatar
Yeah could be a bearing.Ive just rebuilt mine also with stock oilpump i have 42-45 cold and about 30-35 hot on idle
Old 05-26-2012, 07:05 PM
moeZ28's Avatar
Those oil pressures seem a little low fellas...my 2001 SS with 111k miles, factory engine holds 60+ at cold start, 45+ at hot idle, and goes up over 65 or 70 when I get on it.
Old 05-26-2012, 07:26 PM
That's MISTER MODERATOR
Paul Bell's Avatar
This sucks dude, I feel for ya. This place had just one person? I'd hunt him down and get my money back. Perhaps even call the cops. You hired this guy to perform a service, you pay him and he disappears. Sounds like he's gonna setup somewhere else and do just one job then "go out of business" again.
Old 05-27-2012, 11:42 AM
ABQ99TA's Avatar
Sounds like a main to me too. I've gone through the same ****. It was two mains and I had the same symptoms you are having. Sorry bro time to pull it apart
Old 05-27-2012, 12:10 PM
BadAndy's Avatar
I understand, but the shop is not actually "the business." Its just a place where you do business. If the business itself still exists you can probably get some kind of compensation.
Old 05-28-2012, 09:10 AM
It was a small business whit 2-3 employee. Cant do nothing about it.
Anyway, the engine is out. I will open it tonight and keep you update. I found 2 shop arround 2hrs drive and they specialise in LS engine.
Old 05-28-2012, 09:24 AM
Paul Bell's Avatar
Sounds good.
Exactly where is "near NY"?
Old 05-28-2012, 08:34 PM
Well, case close. Engine need rebuilt
Crank Bearing #1
Crank Bearing #2
Crank Bearing #3
Crank Bearing #3 front (not shiny)
Crank Bearing #3 back (very shiny)
Crank Bearing #4 (On the left side, you can see some gold spot)
Crank Bearing #5
Quick Reply: gold/copper dust on new rebuilt
