How to add airflow?
Old 05-30-2012, 10:19 PM
marthastewart's Avatar
Default How to add airflow?
So I got it to run and start up good with no ac. if the ac is on when I start it it fumbles a little then dies. have to keep the foot on the gas to keep it running. Once I get moving it runs great and no more problems. What should I be looking at? I dialed in the RAF and dont think the RAF needs to be messed with since its running/idling great without the A/C turned on. What table can I adjust to give me more air only when its hot and ac being on? I am using HP Tuners.
Old 05-30-2012, 10:30 PM
ghost-1's Avatar
under idle/airflow I have my max in gear max is .132 and min is -.397, ac offset max/in gear set to .066 and my ac offset filt at .0050
Hope this helps.
Old 05-30-2012, 11:17 PM
So if mine is set to -.50 min and 4.50 max then mine should be even higher and allowing more air right? Or am I misunderstanding this table?
File Type: hpt
