Vehicle Classifieds - 2001 Chevrolet Camaro z28 m6, lots of goodies
zfrank
05-31-2012, 06:56 AM
2001 Camaro Z28 $12,500 66k miles
CALL/TEXT for pics or Any questions 606-219-2198 or message
Like to sell but may be interested in crotch rocket, small daily driver car, rzr side by side!!
Stock LS1 with ARP rod bolts
224 224 581 581 112lsa cam
stock heads 7 angle valve job and ported.
918 springs, comp push rods
ported oil pump, ls6 timing chain, ASP pulley
tranny has been built by Bill Plummer in VA.
it has all the goodies in it should hold 750lbTQ
clutch is a RAM extreme HD, its never slipped. with ram flywheel.
pro 5.0 shifter, harlan programable shift light
line lock
fast toys ram air, bauer ported tb, whisper palstic maf ends, slp smooth bellows, ls6 intake, k&n filter, Kooks long tubeheaders, true duals exhaust rigth before the axle.
BMR lca's, sfc, and PHR, BMR lca brackets, Sphon exteme duty TQ arm, BMR drag sway bar, 6 point roll cage.
hals 12 way adjustable shocks on all 4 corners, BMR tubular k member, upper and lower a arms, air bag in right rear spring, v6 springs in the rear, 12 bolt moser with 4:11 gears 35 splins axles posi trac, almn drag cover, extend studs, 6 xtra stock rim and tires, all kinds of spare parts,
17" c 6z06 wheels with nittos r on car noW.
zex nitrous kit. Used on car 1 time on dyno
Vfn Sunoco hood or vfn stock appearing hood
Could be Forgeting someone, it's a really good car just looking for something else to play in
KAOS
05-31-2012, 08:01 AM
Where in ky
98C5
Do you have any pics? Dyno numbers?Does it still have a/c? I have a 2012 RZR S LE I may be interested in doing some trading.
zfrank
05-31-2012, 08:21 AM
Stanford ky
418rwhp on dyno
No heat or AC
Txt me for pics!
KAOS
05-31-2012, 08:56 AM
Do younhave the components to out heat back in
zfrank
05-31-2012, 10:11 AM
No it was out when Ibought car
zfrank
06-01-2012, 05:27 PM
TTT... Someone needs a nice car!
