Camaro Partout Whats Left LS1 TCI FLEXPLATE
Category: Accessories
Price: $2147483647
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird
Location (State): FL
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
A4 Pedal assembly $25
Shifter Cable $20
Motor mount perches $20
Side Mirrors $30
Coolant level sensor $25
Coolant resv. $20
Torque arm $20
Steering Column $40
Driver side Window reg/motor $30
Battery cable $25
TCI Flexplate $185
Headlight Switch $15
Trunk release $15
Rear Spring Isolators $10
Rear calipers and brkts (grinded for drag wheels) $40
Stock 5.3 cam 40k $30
SLP Line Lock w/ master cyl. $90
Ash Tray $3
Truck coil brkts $40
Throttle Position Controller $40
98 Camaro PCM (tuned by FROST for 3.73 gears) $50
Starter plate $5
Fuel Pressure Regulator $20
AC ***** $8
Cluster $40
Fans $50
Pass switch $15
ASR/FOG Switch $5 ech
I am interested in the motor mount perches for $20, the cluster for $40 and the fans for $50. Are you anywhere near Ft. Lauderdale or the keys? I'm flying there tomorrow. Otherwise how much shipped to 60432? Thank you!
Chris
1-815-277-6846
Call/text
Chris
1-815-277-6846
Call/text
