Side Exit True Duals
I am thinking about getting true dual's with high-flow cats into an X-pipe and Dynomax bullett's that exit on before the wheels on the sides of the car. Does anybody have a similar setup to this? I currently have Jet Hot LT's, a custom 3" Y, cutout, and Corsa cat back.
I'd like to see some pictures before doing this. Also, does anybody know how loud this will be? I need to quiet down my current setup (I keep getting pulled over).
yeah dude i agree with wicked 98 i did it too, even used 2 1/4 inch piping after the mufflers, and ground clearence was a major issue. plus you have to put the hangers on a peice of frame which makes the vibration echo through-out the car. it sounded really good with the set of new flowmaster mufflers i got, they are smaller 40 series mufflers and they tucked up nicely just the side exits didn't do so hot. scraped them alot
check out the magnaflow mufflers, a guy on this board just recently changed his dump set up to those from bullets and they sounded great too. do a search he posted up about it just a few days ago. 02 southfl or something like that can't remember off the top of my head though
goodl uck
Travis
goodl uck
Travis
it would be bad *** if it was set up like the vipers, where the pipe ran down the side of the car, but behind the body molding, but theres no way it would fit our cars, nor would any kind of rocker panel or body kit look good to cover that up. Have you looked into those 'boom tubes' or whatever there called? Arent those the flat exhaust pipes?
