5.3 fox finally runs!!!!!
Old 06-11-2012, 05:52 PM
bakomack's Avatar
Default 5.3 fox finally runs!!!!!
She runs and I'm so stoked its been 6 months since I started this.
Last issue to deal with is alternator.
I have a 4 pin alternator and 2 plug pin on the harness.
I ran the main power from the batt to the Alt but what do I do about the 4 pins not connected to the harness?
Old 06-11-2012, 07:26 PM
Chrome_Rust's Avatar
What are the colors?
Also did my fuel pump power suggestion work for you?
Old 06-11-2012, 09:34 PM
dec010974's Avatar
hello bakomack. to answer ur question ur gonna have to switch the alternator connector. its a 4 pin connector that has (1) wire that runs to #15 in the green/red side of the PCM. in stock form its a brown wire. the b slot on the 4 pin alternator connector will run to the pcm.
Old 06-12-2012, 09:42 PM
bakomack's Avatar
I ran a 12v ignition wire to pink/blk wire and fixed the issue. Thanks a lot man finally got the car to run.
The 2 wires to alt are brown and gray. Can I solder on a 4 pin plug in place of the 2 wire plug? Can someone get me the location of where each wire needs to go?
