HELP... oil cooler adapter housing
Old 06-13-2012, 10:02 AM
tt383lt1's Avatar
Default HELP... oil cooler adapter housing
i need to buy a oil cooler adapter housing. will a normal sbc oil cooler adaper work? or does it have to be made for a lt1 engine?
Old 06-13-2012, 04:54 PM
tt383lt1's Avatar
to the top
Old 06-13-2012, 05:57 PM
96capricemgr's Avatar
Standard sbc one fits the engine.
The Caprice LT1 one tucks tight to the pan if you need clearance, of course then you would need the lines that attach and probably have to cut them at the rubber part for custom routing. I just thought I would mention it because I figure with twins you have space concerns.
Quick Reply: HELP... oil cooler adapter housing
