ok im a little stuck
hey guys i am just about to start the process of swapping in a trex in my 2000 ws6. it has 79000 on it so i figured it would be a good idea to change out the lifters as well. My problem is that the trex is going to have a very tight ptv clearance from the start and i know that you should cut the heads everytime you are removing and installing them, especially aluminum. Im just wondering what should i do? do you think i would be ok without cutting them, should i not change the lifters? thanks guys
