347 forged LM7 and Built 4L80
Category: Engine - Complete Motors
Price: $10000
Part Fits: 2010+ Camaro
Location (State): MI
Item Condition: Brand New
Engine: LS1/LS6
LS Engine?: Fits LS Engine
Lunati rods and Ross pistons,3.900 bore, L92 crank, 9.33:1 compression. Comp custom 6.20 lift cam, world challenge CnC'd heads. LS6 valves, C5R head studs. GM MLS gaskets. Comp dual valve springs. Trend push rods, stock lifters katech oil pump and chain. LS6 intake, katech ported throttle, ported 5th gen camaro exhaust manifolds. 5th gen oil pan and the Gm performance parts hot rod swap pan.
LS7 front drive and C6Z alternator and water pump. Katech tensioner, Billet oil cooler and turbo feed and a set of fast fuel rails. All new.
truck ECU and Harness.
New Borg Warner S480 turbo.
Built 4L80E, 2004 model. Its got all the good clutches in it and the good sprag. None of the billet parts though. It was built by lakeside transmissions and I paid 1300.00 for the build alone. I have the bill also. Its been sitting in my heated shop since it was built and has zero miles on it.
10k for everything.
Might be willing to split some things up, turbo, trans, front drive ect.
motor_city_mechanic@yahoo.com
248-805-2358
