6.0L mild build what to buy
was thinking of alum heads - i just emailed AI to see what the timeline is for a set. as the Trick Flow Specialties TFS-3061T001-C02 - Trick Flow® GenX® 225 Cylinder Heads for GM LS2 are $12oo each cost
mild cam-
new rings-bearings-oilpump-
Arp bolts..
are the rods fine to reuse?
i have a holley pan retrofit already --
what else should i replace?
mild cam-
Arp bolts..
I'd replace the rod bolts while your in there with a set of ARP or Katech bolts, and look at a low to mid 230's cam.
Also pick up an ls2 chain and ported ls6, or melling oil pump
