WTB LS6 Long / Short block
I need a LS6 to put in my 03 Z06 it had the old the broken valve spring and valve drop issue. Block is junk. My zip is 45140 and the address is commercial. Thanks
Dave
Dave
I have a small block, that is built. It has a stock crank, forged rods, and forged JE pistons. Two of the pistons need to be changed, as the ringlands cracked due to detonation. The block is fine, and it still holds compression. I would haven't known that they were cracked if I didn't do a head swap. the engine ran great. Let me know if you are interested.
