Upr k member and flaming river steering shaft no work on my fox
Old 06-24-2012, 09:27 PM
bakomack's Avatar
Default Upr k member and flaming river steering shaft no work on my fox
Been building this pos for a while finally got it to run now have problems with steering fitment.
1988 foxbody hatch and is a manual 5 spd.
I converted it to auto and has a UPR k member on it now
I'm using 2010 camaro manifolds and I ground down on the flange some but still can't pull enough Clarence.
I'm using solid motor mounts and they are on the very front slot. I'm using a aje tubular trans member and it's back as far as it will allow with out cutting the brackets and moving them back and rewelding.
I have the flaming river steering shaft and the joints are at their max
Is there another way around this problem?
What have other people done to remedy their problem?
Old 06-24-2012, 09:34 PM
racerrit's Avatar
351 headers with ls flanges.
Old 08-02-2012, 11:06 PM
1bad03snake's Avatar
I have a flaming river shaft and it hits on my dynatechs. Going turbo soon so it wont be an issue
Old 08-06-2012, 11:21 AM
MustangLS's Avatar
Any pics of the issue?
Is it a 4.6 K-member with solid 4.6 motor mounts? Are you using adapter plates or did you modify the solid mount to fit the LS engine.
Old 08-06-2012, 07:17 PM
Sarg's Avatar
I am not sure that this whole 4.6 kmember and mount thing is the way to go. I tried that and I was unhappy with the fitment of the steering rack or the way the engine sat in general. Thankfully I was trying it with my plastic mock up block and not the real motor or I would have been quite irritated. Maybe we should start a combos that DON'T work thread along with ones that do work for future swappers.
Old 08-07-2012, 02:59 PM
MustangLS's Avatar
It might depend on the chassis. I have the UPR K-member, 4.6 motor mounts and adapter plates in my SN95 car with a flaming river rack and dynatech headers and no issues anywhere. The engine sits back about as far as you can go and the cross member is a modified stock one.
Old 08-08-2012, 11:13 PM
bakomack's Avatar
Ended up solving this problem by calling flaming river and ordering the 6" tongue they offer for 40 dollars
Quick Reply: Upr k member and flaming river steering shaft no work on my fox
