What to coat cam with for install?
Old 04-01-2004, 12:24 AM
HOTROD98Z's Avatar
Default What to coat cam with for install?
I am going to be putting my cam in this weekend and i know most people just coat it in motor oil, however it will probably be at least a week before everything is buttoned up and it is ready to be fired up. So will oil be alright or should i use some type of assembly lube?
Old 04-01-2004, 12:54 AM
Krab's Avatar
I used oil on mine and didn't have a problem. I think it'll be just fine with motor oil.
Old 04-01-2004, 01:07 AM
wrencher
wrencher's Avatar
Assembly lube is good stuff sticks really well.
It would stay better than regular motor oil.
Old 04-01-2004, 02:41 AM
I can shift faster than you.
Jason99T/A's Avatar
If you will be starting the motor up right after you finish the install, oil will work just fine. If it will be a few days before it is fired up, some assembly lube would be prefered.
Jason
Old 04-01-2004, 03:30 AM
distortion_69's Avatar
I used motor oil. Didn't fire car up for over a week.. no problems. I think whatever you choose will work. Just be sure to coat it very well to where its just freakin soaking and you'll be fine. Assembly oil would be a good safety net tho
Josh
Old 04-01-2004, 04:49 AM
PREDATOR-Z's Avatar
Cam lube for sure. Why take a short cut for something that is less than $10. What if something went wrong with the install and no oil is getting to the cam on start up? The lube would give u a fair safety margin for those valuable first couple of minutes.
Old 04-01-2004, 06:26 AM
98blackSS's Avatar
coat it with motor oil just before installing.. assy lube is not needed..
Old 04-01-2004, 06:49 AM
DaleMX's Avatar
Assy lube with moly in it. No sense in not protecting your investment. Might not be necessary, but what if you have 0 pressure at start up from a bad oring, or you screwed something else up during the assy? Protect your investment!
Old 04-01-2004, 04:59 PM
HOTROD98Z's Avatar
It looks like i will be going with some assembly lube, thanks guys.
Old 04-01-2004, 05:16 PM
DenzSS's Avatar
Old 04-01-2004, 05:18 PM
gun5l1ng3r's Avatar
Sounds like DaleMX has the idea that is what I am going to be doing.
Old 04-01-2004, 05:31 PM
2xLS1's Avatar
So what does everyone do when their car sets for more than a week without starting it? Tear the motor down and coat everything with assembly lube???
You will be fine just using oil.
Old 04-02-2004, 06:25 AM
98blackSS's Avatar
it's just old school mentality.. let them be I see no benefit in going through the extra trouble of using lube on any roller cam.. The what if's were amusing to read though...
