LS1 Swap into 68 Camaro
Old 06-26-2012, 11:00 AM
Vicinity's Avatar
Default LS1 Swap into 68 Camaro
Couple of quick questions. I know the Fbod oil pan needs modification to fit (with setback mounts??), can a gto pan be worked over the same way?
Will the GTO accessories work like the Fbody accessories will? (IE Fit)
Basically, I have the choice between a GTO and an Fbody LS1, I'm wondering which would be easier and cheaper to swap in. The Fbody LS1 @ 1600 for everything (minus the harness) and the GTO @ 2200 for everything (including harness).
Old 06-26-2012, 11:09 AM
LS1Tech Sponsor
psiconversion's Avatar
Regarding wiring/PCM,
GTO is going to be DBC with a Green/Blue PCM and FBody is going to be Red/Blue PCM with DBC. Alternator wiring is different and O2s are different as well.
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old 06-26-2012, 04:44 PM
Vicinity's Avatar
http://secure.ultracart.com/catalog/.../PCM-1004.html
That just says, Red/Blue. Do you offer reprogramming for the Green/Blue? What kind of turn around time do you have?
From what I've found so far, you have the best price on PCM reprogramming...
Also, quite possibly a stupid question, so make sure you're sitting down, but those harness prices, are reworked (as in a core need to be sent in) correct?
Old 06-26-2012, 04:51 PM
bczee's Avatar
The GTO is a front sump pan.. going to take way to much work to modify it.. better off starting with something closer to the rear sump pan.
I think the GTO Front accessories should work ok.. but well let other that have the setup ping in.
BC
Quick Reply: LS1 Swap into 68 Camaro
