Gears & Axles - Rear End suggestions!!
View Full Version : Rear End suggestions!!
drebear34
06-28-2012, 09:46 AM
Hello everyone, I just recently put my 2001 WS6 in the shop. My transmission just wasnt acting right and my rear end was jacked up. Okay, here's my question, I found out from my mechanic that I have a 3.23 posi-trac rear end. Is this the best for my car? Thanks!
garygnu
06-28-2012, 10:52 AM
what tranny do you have ,A4 or a M6 ?how much are you making ,or plan to make ?with stock to mild power level your rear axle is ok.if you like to go to the strip alot with sticky tires consider upgrading to a 8 3/4,dana 60,12 bolt or a 9" rear.I have seen 9" rears for your car for $1800 in the used parts section.
drebear34
06-28-2012, 11:35 AM
Lol... my tranny is A4. Now dont get me wrong, Im am very pleased with the power I have now, I was just checking to see if the rear end I have now was strong enuff for my car. Havent done any strip racing.
02 SSilver Bullet
06-30-2012, 08:36 AM
Didn't notice what your mods were but you're probly good to go. Simply changing your gears from 3.23 to a closer ratio while you've got the rear end dropped is an opportunity to add power cheap. 3.73 good for highway running, 3.90 & 4.10/4.11 good for street or light to light.
mjs1012
06-30-2012, 08:43 AM
For an a4 many people seem to use 3.73s. That with a good converter will be a nice combo.
Ethan[ws6]
07-01-2012, 12:18 AM
Best for what? By the way you described the rear end, I'm lead to believe that you don't really even know what any of that stuff means lol. You have a factory rear end. If it's not broken, don't worry about messing with it.
