Solid roller 408 for sale, carb'd with distributor
Category: Accessories
Price: $7500
Location (State): OK
Item Condition: Used
LS Engine?: Fits LS Engine
Iron 6.0 block, 4.030" bore
Ohio 4" light crank, std. on rods, .010 on mains
Ohio 6.125 H-beam rods w/ ARP 2000's
Custon RaceTec dome piston, 13.5:1
Race rings, 1/16-1/16-3/16
Race bearings
Melling 10295 pump
ARP main studs and head bolts
Howards solid roller link-bar lifters
COMP custom billet roller cam, 256/260* @.050, .690 lift, 106LSA, have card, sounds really nasty
Ferrea stainless 2.08/1.60 valves, +.100 length
Manton pushrods
COMP 1.550" roller springs, Ti. retainers, COMP keepers
Yella Terra adjustable 1.7 rockers
DART 225 casting heads, a lot of work, custom 50* valve job, now are at 235cc intake runner, 56cc combustion chamber
AllPro valve covers, driver side cover has two alum. breather tubes welded in
Cloyes adjustable timing with good chain
GM distributor conversion with MSD billet ready-to-run distributor and coil
Stewart long water pump, std. rotation with mech. fan hub
ATI Super Damper
Edelbrock Super Victor intake with HVH 2" lightweight tapered spacer
Nice Wegner pulley set
Kevco circle track oil pan, baffled with multiple trap doors
Moroso oil filter adapter, -10AN fittings
Would add the Holley hardcore black 850HP for another $500, was bought brand new for this engine, has same amount of time on it as the engine.
