n00b question for geniuses like yourself about general diablo predator tuning?
2000 pontiac trans am ws6 with 4.10 gears manual 6 speed
guy I bought the car from had a diablo tuner with it. He said he just installed the stock program that diablo recommended for his car to gain a little horsepower while also using it to correct the speedo because of the gear change + skip shift removal. My questions are:
1) is the stock program diablo has on it the best option ? I'd like to get a little more aggressive than the stock setup if possible but also stick with being able to drive it daily, not kill my gas mileage, and 91 octane.
2) If not, is there a website or posting about the best settings? A step by step guide for a semi computer/pcm illiterate guy like myself?
Sorry if this question has been asked before. I used the search but could not find what I was looking for, and the stickies in the pcm thread were more of an overview. Thanks guys n' gals!
LS1Tech Sponsor
is it a newer version predator on a 9rXX revision number? if so, you will be able to record data logs to see where your average LTFT's are at, and can make some fueling adjustments... power it up, and when it gets to the main menu, the revision number is shown at the top of the screen...
here's info on diablo's forums about data logging:
http://diablosport.com/index.php?nam...iewtopic&t=917
but, if that predator is an old one on a 2.xx revision, then you can record data logs...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
