How much should engine tilt back? Fox with 6.0
Old 07-01-2012, 05:37 PM
streetknight2's Avatar
Default How much should engine tilt back? Fox with 6.0
Just set my 6.0 in my fox Mustang. Using stock mustang trans cross member and aje k member. It looks like its tilted WAY too far back. Put a protractor on the intake and it has 6 degrees of fall. I shimmed 1/2" between x member and trans mount and still have 3-4 degrees.
What is correct?
Old 07-01-2012, 05:41 PM
windmill's Avatar
i know they say the sbc motor intakes have a 3 deg to the front,,,, make sure the car is on stands and level,,,,
Old 07-01-2012, 07:03 PM
i r teh noobz's Avatar
The generic spec I was always told is 3-5 degrees. Mine sits around 5 and is fine. Measure the pinion angle and match it if you can.
Quick Reply: How much should engine tilt back? Fox with 6.0
