Sponsored by: DashLynx
projector flicker problem
Old 07-05-2012, 12:34 AM
TX RED's Avatar
Default projector flicker problem
Help
Old 07-05-2012, 05:58 AM
BLSolutions's Avatar
When you mentioned you swapped ballasts and lamps, did the issue stay on the passenger side? Looks like the lamp isn't getting full power to start completely. Did you contact TRS directly?
Old 07-05-2012, 07:42 AM
TX RED's Avatar
Not yet I was going to send them an email today
Old 07-05-2012, 07:43 AM
TX RED's Avatar
Yes the problem is on the rt side only
Old 07-05-2012, 08:18 AM
I spoke to them and showed the video. They believe it to be a power issue. I think we went over this before but I would see if running the car and letting the battery fully charge solves the problem. The flickering going away when you unplug the driverside ballast suggests there isn't enough power to keep both lamps lit effectively.
Old 07-05-2012, 08:44 AM
TX RED's Avatar
I'll try it later today the battery is pretty new only a couple of start ups on it.. But I'll let it idle for a bit then try it
Thanks Brian for help
Quick Reply: projector flicker problem
