-06 feed for 700rwhp turbo
so i was wondering if i should just go bigger diameter on my fuel feed line. I plan on running twin 255 pumps into a single -6 line and putting a Y at the rails where a -6 line runs into the rear of each rail. i was going to put a bypass regulator at the front of both rails with the return going back into the stock feed line.
i wasn't sure if -6 feed would be adequate but seeing as how most fuel rails would bottleneck a -8 or above feed down to 3/8th or -6 inner diameter at the rail anyway, i figured -6 would be ok as long as pressure holds in the rail.
the goal is to make 700 rwhp on 93octane with this setup.
