Fueling & Injection - Injector buying time
View Full Version : Injector buying time
bradw18
07-08-2012, 02:06 PM
I'm to the point In my build were its time to buy injectors. I'm looking heavy into running e85. I don't wanna buy 2 sets of injectors. I'm running a 5.3 with 856 castings ported like crazy 202 160 valves. A 85mm typhoon that's port matches to the heads, v2 cam. Iv built my fuel system to handle e85 with 8 an feed line and each fuel rail has a return line that goes back to the regulator. Was hoping to have 430 or so hp. Will the ford 42lb be enough if I decided to run e85?
bradw18
07-10-2012, 01:04 AM
Anybody?
TransAmcoupe98
07-10-2012, 02:11 AM
You're going to get better and more informed responses in the fueling and injection section.
