Fast toys lid conversion
Old 07-11-2012, 12:33 AM
1320z28's Avatar
Default Fast toys lid conversion
Came across a 104mm air lid, I'll be building a 355 with a lot of nitrous anybody do this particular lid swap?
http://fasttoys.net/shop/Fast-Toys-Black-104mm-LS1-High-Flow-Air-98-02-Camaro-Firebird-LS1/
Old 07-11-2012, 01:39 AM
jewbacca's Avatar
That thing gonna fit under the hood? I have the lid swap on my car, and that's a pretty tight fit as it is.
Old 07-11-2012, 03:53 AM
Blk98Vert's Avatar
What hood do you have, the hump on the FTP lid makes clearance even tighter
Old 07-11-2012, 05:01 AM
96lt1m6's Avatar
Sunoco wide
4" cowl
Will be the only way to clear this lid providing you are using the complete lid assembly.
Old 07-11-2012, 11:47 AM
1320z28's Avatar
I will be using the 4" Sunoco hood and trimming the radiator. The hood will be pin on as well
Old 07-13-2012, 09:27 PM
SmokedOutZ28's Avatar
I have that lid on my car.... with the Glas tek 4'' hood I had to do some trimming on the hood and ALOT on the lid base but I didn't need to touch the radiator support. If you trim in the right spots it should fit.
Old 07-16-2012, 07:28 PM
BADHAWK51's Avatar
That's what I run on my car with a 4in vfn hood. I trimmed the bottom of the base to get it to sit a little lower and that's about it.
Quick Reply: Fast toys lid conversion
