is this going to be a good cam
good afternoon everyone, buddy of mine has a cam he got for his car and he decided he wanted to go a different route with the engine now im thinking about buying it off him and want to make sure the cam will be good for the cars setup.
i have a 2002 z28 camaro a4 has 70300 miles on it.
cam specs:
duration is 224 intake 224 exhaust
valve lift is 581 intake 581 exhaust
lsa is 111
this would be installed this winter along with sending the heads out to get p/p
tsp lt/ory
ss3600 stall
p/p tb
and 3:73 gears
just wanting to make sure this combo will be good
any and all help will be appreciated thanks
cam specs:
lsa is 111
tsp lt/ory
ss3600 stall
p/p tb
and 3:73 gears
110 ICL is not bad, good grind that will give you 42 IVC which is about perfect for street. Make sure you degree it at that ICL. Power range will be around 2000rpm to 6600rpm
