speedshifter
07-13-2012, 07:58 AM
Hey guys,
Tonight I'm picking up a 6.0L LFA (http://en.wikipedia.org/wiki/GM_Vortec_engine#LFA) engine with 92k on it. It had valvetrain noise. Heres what I have planned for it right now.
Stock crank
New crank/rod/cam bearings
ARP bolts
L92 heads w/GM gaskets
LS3 intake/TB
LS7 lifters
Ed Curtis custom cam & pushrods
Comp Trunion'd stock rockers
LS3 oil pump
F-body oil pan
LS3 front cover & valley cover
3 bolt timing chain
This is going into my '95 Mustang. My goal is 500rwhp on a budget. I know that is going to be tough, but if it only makes 460+ I won't cry about it. I know I could get to 500 with a stroker kit and sick heads, but don't got the dough for it now.
Originally I was under the assumption that this motor was lower miles and I was just going to re-ring the stock 10.7:1 pistons. I'm not a fan of GM pistons or rings, but it suits the budget. Now finding out that there is 92k miles on the motor, I'm telling myself I better do pistons and rings. Question is what do I go with? This is going to be a pump gas street car, road raced and/or drag raced handful of times a year. I'd like to be around 11.0:1 CR. Can I clean up the cylinders and stick with a 4.000" piston or do I need to go larger?
I found this deal on ebay from SLP. Although its more than I want to spend, its like buying a set of pistons/rings and getting the rods for $150 more. I wasn't planning on doing rods, but for the deal....
http://www.ebay.com/itm/220964653627?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_3492wt_1139
What are your suggestions for pistons for my application? I have been looking for pistons for an LS2 application, seeing as this is a 6.0L aluminum block.
Thanks for your help!
Stock crank
ARP bolts
LS3 intake/TB
LS7 lifters
LS3 oil pump
F-body oil pan
3 bolt timing chain
