6-Piston Stoptech Big Brake Kit - NEW
Closed ex-Sponsor Account
Category: Brakes
Price: $2000
Part Fits: Corvette
Location (State): KS
Item Condition: Brand New
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
Complete Stoptech ST-60 Front Big Brake Kit for the C5 / C6 Corvette. This is brand new in the box and includes everything listed below:
(2) ST-60 - 6 piston calipers
Black powdercoated finish
(2) 355mm (14") slotted rotors
High performance pads - still sealed in the box
Stoptech Performance stainless steel line kit
C5 / C6 Caliper Brackets (black hardcoat finish)
- everything you need for installation
Stoptech Performance Big Brake Kit
Stiffest Calipers Available
Improved Pedal Feel And Modulation
Patented AeroRotor Hats Are Specially Heat Treated
Shortest Stopping Distances Possible
Proper Integration w/ABS/Vehicle Dynamic Systems
Championship Winning Performance
Patented Removable Bridge/Floating AeroRotor
Application Specific Balanced Brake Upgrades
Product Description
The ultimate in brake upgrades comes in the form the the Stoptech Performance Big Brake Kit. Remove your lousy stock size brake rotor and caliper combo and replace them with high quality, max performance Stoptech rotors, calipers and pads. Larger rotors means increased heat capacity and also better venting allowing the driver to brake harder, longer. The Calipers are rated stiffer than most competitions 2 piece calipers and complimented with stainless steel lines to reduce system compliance, providing consistent pedal feel and confidence-inspiring responsiveness.
