Vvt cam by mast motors ports
Category: Engine - Intake/Fuel
Price: $300
Part Fits: 2010+ Camaro
Location (State): AL
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9
LS Engine?: Fits LS Engine
Mast is THE leader in LS cam technology. Want proof? We had variable
valve timing cams 18 months BEFORE anyone in the aftermarket. We
design our lobes IN HOUSE using proprietary software. We test each cam
on our NCRS Superflow engine dyno in actual applications to find the
best power curve. Then, we test each profile in “real world”
conditions. After many grueling hours, we select a profile to be
manufactured to our precision specs. from select billet cores.
Mast Motorsports cam notes:
Headers are recommended on every GM Gen IV app. to significantly
enhance power improvements from camshaft swap. Mast Motorsports
recommends that every cam be accompanied by a calibrated tune using HP
Tuners, EFI Live, or equivalent software.
Application Valve Setting (In. Ex.) Idle Quality Cam Part # Cam
Package Part # Duration @ .050" (In. Ex.) Valve Lift (w/1.7 Rocker)
(In. Ex.) Lobe Sep. Angle
Camaro & Escalade VVT Cam (L92 & L99) Hyd. Hyd. Mild 914-201
964-201 220 234 .570 .588 116
