General Maintenance & Repairs - need help asap!
coryratcliffe
07-25-2012, 02:10 PM
I was in the process of relocating my battery to the trunk got everything al ready and when to put the connectors on the terminals and goofed and put them opp(neg on positive and vise versa) seemed to be no problem but i did blow a power acc fuse my question is now since that point ive had a drain on my battery that ive never had before till this happened its a very noticable drain on a dvom i can watch it drop. Any help will be much appriciated.
DisasterFormula
07-25-2012, 02:51 PM
Trace your wires and make sure you didn't melt any wires, no wires are grounding out where they shouldn't be, etc. Wiring, wiring, wiring. It's a bitch.
wssix99
07-25-2012, 03:36 PM
I recall seeing other threads with the exact same problem. Did you do a search?
coryratcliffe
07-25-2012, 05:06 PM
yes but at the same time none of them involved hooking the the power and ground to battery wrong by accident most are i was wiring a system or radio things ive taken the fuse out unplugged the acc on the fuse but still can find my drain is it possible it could be alternator or starter or am i just missing something acc wise inside?
wssix99
07-25-2012, 07:03 PM
Yes, others have done it. I've seen posts but don't recall any resolutions to the problems that came up. Those posts may be hard to find, but its worth a try to find them.
farmington
07-25-2012, 07:24 PM
pull the fuses one at a time until you find the circuit with the drain
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
