crank case pressure under boost
I seem to be having a problem with my crank case pressure under boost. I either blow it out the dipstick tube or the rear main if I zip tie lipstick tube in.
Any advice on a vacuum pump/ oil catch can diagram? I have a PVC in drivers valve cover and a hose from passenger valve cover to oil catch can. if I hook. vacuum pump to other side of oil catch can do you think this will cure my issue?
The following users liked this post:
Homer_Simpson (08-07-2023)
do a compression check if you are pushing the dipstick
I have tried venting to atmosphere only on both sides. it makes mine smoke out the exhaust bad. I was told by machines that I had to run a PVC in one valve cover because of the design of the oil tubes in engine block. he says without the vacuum being pulled it will cause my oil return line to turbo to back up and smoke thru turbo.
I'm going to do a cyl leak down test this weekend. I really don't think anything internal is hurt. it has no blow by at idle or reviving. only under boost. I'm pushing 20+ so its finding all the little gaps for sure.
