Ligenfelter HD rocker arm stands
Old 08-04-2012, 05:16 PM
toadzq8's Avatar
Default Ligenfelter HD rocker arm stands
Just bought a set the steel HD rocker arm stands, for LS6 build, the stands are threaded, I thought they should be just clearance holes like the factory stands. Is this right?
Old 08-06-2012, 02:16 AM
99Bluz28's Avatar
So do your rocker bolts thread down through them ok?
Old 08-06-2012, 09:52 AM
toadzq8's Avatar
that's the problem the thread does not allow the rocker bolt to go through and thread into the head!
Old 08-06-2012, 10:25 AM
427's Avatar
Did you try a bolt? They might tap them bigger for production of the part. See if your 8mm bolt will go in free.
Kurt
Old 08-06-2012, 12:40 PM
Ronny_02_WS6's Avatar
I have those, All you have to do it's rotate them till they connect (thread) to the heads, they fit fine with the stock rocker bolts and even better with the Comp Cams trunion upgrade.
