Hardware question... anybody??
Just ordered a panhard bar, panhard relocation, and strut tower brace.. I'm just a little confused as to what goes to what. I know everything circled is used for installing the panhard relocation. What about the third bolt, the other 2 washers (which are slightly bigger/thicker than the other 4) and the last nut? I assume its for installing the panhard bar, but am I only supposed to have hardware for one side?
Another reason I'm asking is the nut in the top of the pic is bigger than the other 2, it doesn't fit any of the supplied bolts. I'm thinking I was sent the wrong one, just not sure.
And does the STB use any washers?
Thanks guys...
Edit: Found this pic in another thread:
Looks like all hardware goes on pass side and Ill be re-using factory stuff on the driver side, I guess the big nut I was sent was indeed a mistake
Thanks guys...
