Ford injector part numbers
Old 08-06-2012, 05:05 AM
gsd2000's Avatar
Default Ford injector part numbers
Hi
Ive found some Ford 24 lb injectors in the UK and i was just wondering if they would fit an ls1.
The part number is M-9593-A302
They are grey top injectors
Ive tried searching and cant find much
thanks
Old 08-06-2012, 06:27 AM
Old Geezer's Avatar
Google = https://www.google.com/search?q=Inje...rchBox&ie=&oe=
Old 08-06-2012, 07:21 AM
FICINJECTORS's Avatar
Originally Posted by gsd2000
Hi
thanks
On the side of the injector it will have the Bosch # 0280150947. They are 24 lb Bosch 2.. They will flow 28.8 lbs at 58psi, and will drop in a ls1. They are the same size as a stock ls1 injector.
Old 08-06-2012, 07:44 AM
gsd2000's Avatar
ah okay,
I must have done the conversion wrong as i assumed that if it was a 24lb ford injector then it would be around 32-33lb in an ls1
if they are 28.8lbs then they are exactly what i currently have
