*SOLD*: Meziere Electric Water Pump
Category: Accessories
Price: $525
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V
Location (State): PA
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
This unit has around 4k miles on it and functions flawless. It is no where near its service life of 3,000 hours and could outlast your engine. This sale will include some options:
1. Relay Wiring Kit upgrade WIK346 - Includes 30 amp relay and weatherpak connectors and fuse holder.
2. Integrated 180* thermostat in the top neck of the EWP.
This unit has two small scratches on it. One is on the idler pulley and is 90% hidden when the belt is on. The other is in the right top and again is barely noticeable when installed. The Meziere EWP goes for $830 on the Meziere web page and that does not include the extras mentioned above. The first $525 (shipped to the lower 48) takes it. PM or E-mail krambo74@hotmail.com.
I used this pump on a truck application and do have some custom machined aluminum spacers if someone is interested as well. These will space out the pump about 5/8in to align with truck accessories.
From their website:
Innovative design makes for an easy installation. Unbolt your factory pump and bolt on an easy 11-14 horsepower with our street style water pump. An idler is incorporated onto the pump so your belt routing remains in its stock configuration. American made with quality far superior to any other performance aftermarket company, we build our water pumps with pride right here in the USA. Don't be mislead by inflated flow numbers and competitors' outlandish claims. Our 300 series pumps move more water and produce more pressure than any other electric pump on the market. That means better protection for your high horsepower, high demand engine! Our 2 year, unlimited mileage guarantee and full satisfaction money back guarantee should convince you that buying Meziere is buying value!
This water pump model features:
•Fits GM LS-1 through LS-8 engines
•Idler design lets you keep all of your serpentine belt driven accessories
•Suitable for street or drag strip use – 3000+ hour life expectancy
•Show quality black anodized finish
•Standard motor provides 55 gallons per minute free flow rating
•Ports provided for heater and bypass
•Outlet fitting, heater and bypass fitting included
•Stainless steel large diameter main shaft with high performance ceramic seal
Technical Specifications:
•Finishing The System: This pump is supplied complete with gaskets, hardware and fittings. No additional items should be necessary.
•Amperage draw: Under normal use the pump will draw 11-12 amps.
•Overall Height Dimension: The standard pump is 7.8" long from the mounting surface to the tip of the pump.
•Pump Weight: This application weighs 14.9 lbs.
•16 volt systems: When purchasing a pump for a 16 volt system we recommend the 16 volt optional motor on our pump. The 12 volt pump will work for limited use applications.
Accessories for LS-X:
