General Maintenance & Repairs - 2001 Formula LS1 head cover removal
Fireman23122
08-09-2012, 04:40 PM
Anyone have any tips on getting that 15mm bolt on the back side of the head that holds the bracket for the AIR system manifold? I want to get the cover off and look for a stuck valve. Also, looking for an LS1 rebuilder in central NJ. I'm pretty sure mine has a spun bearing based on the amount of metal I found in the oil pan. Didn't see much in the filter.
Reckless
08-10-2012, 09:04 AM
Lots of stretching and a 15mm ratchet wrench usually works
Armageddon
08-10-2012, 11:27 AM
Stubby wrench or ratchet works best for me.
Fireman23122
08-10-2012, 12:32 PM
Thanks guys, I'll give it a try when the rain stops. lol
csess
08-13-2012, 09:42 PM
You do know you only gotta get the bolt loose right? Instead of a bolt hole its a u shaped tab....loosen bolt a little an slide bracket out. If i can get it anybody can get it....lol
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
