xxKennyDxx
08-09-2012, 05:45 PM
Hey guys,
Well where do I start. This problem has been bothering me for the last 2 weeks, and has downed the Formula since.
I had a friend of mine who has a shop install my TSP headers, my Poly MM's, as well as spark plugs (NGKTR55) and wires (MSD). I also got my computer swapped by Bryan at PCM4LESS and loaded it as soon as install was completed. Bryan has tuned my previous LT1 Caprice, never had an issue. I contacted him and he would try to load the tune on my ORIGINAL PCM (not the one I swapped in) to see if it was a computer issue-- but the thing is the car DRIVES GOOD, no idle issues, nothing....she purrs like a kitten. I thought maybe I needed a CASE relearn due to a PCM swap, but that did not fix the problem either.
At first start-up, nothing was wrong-- aside from a exhaust leak that was fixed up (loose header bolt). I drove for a day or so, and no problems-- she ran GREAT. Upon about, I'd say the second day, I was driving around and all the sudden I looked at my dash and my SES light was blinking repeatedly-- then went to solid.
I went to Autozone and ran the code, it came up p0300 (Multiple random misfire). There were no "1", "2", or anything indicated which cylinder this was coming from.
The first time, we looked at it again and it happened to be a number 8 spark plug that was cracked. One of the MSD wires wasn't completely on that number 8 cylinder, so we thought that this was causing the miss when we replaced the number 8 plug (What a pain in the ass, and I have small hands!) Swapped it out for a new one, drove it for a day--- SES came back flashing-- this time more and more. I drove it immediately home (I was doing a test run a mile down the road, back and forth to see if I could trigger this). After some problems people had with MSD wires, I thought it was maybe the wires themselves--
So, the next weekend I dropped my car off and put the stock wires back on. My friend had a buddy who has HP Tuners to check the car to see what was going on- He could find nothing out of the ordinary and the tune looked good from what I was told. So, stock wires back on, spark plugs re-checked for any problems (They were all fine).....take it home. The next day, after about 20 miles-- SES light p0300 again, and this time flashing a little less than the last time. So, I parked the car...and haven't driven it since Monday.
The way this misfire happens is interesting. I am in low RPM (1500-2300), in 3rd or 4th gear usually...the latest time this has happened is when I was going DOWN a bridge by my house. I get a little nervous when this light comes on, because it never had prior to my header install.
When I took it back to Autozone to get the code, the tech there mentioned a Crankshaft Position Sensor, and showed me some values that were going up and down (I forget which value it was), and he mentioned to look into it-- I haven't but upon reading on the forums-- It is a problem that can happen.
The coil packs are connected (two clicks) to the plug wires, and are secured in place (I know one guy had the issue of not connecting them which resulting in a misfire, just thought I would state that that wasn't the case)
I have done lots of searching for this code on here, so I guess I know what three areas this could be: Fuel related, electrical, or mechanical.
-----I thought "Ok, you know what....not sure if I put 87 grade gas for my 93 tune two fills ups ago--(I am 99 percent sure I DID...but I get confused sometimes because I fill up both my truck and car and might not have been paying attention at the time)" So, I have read some bad gas could cause a misfire-- I will up with a full tank of Shell 93. Next, maybe my MAF sensor is dirty or on the way out-- I will try to clean it, or disconnect it like some people have mentioned and see what happens.
Anyway, if you can understand where I am coming from-- I do not want to take the "throw parts at it and burn my wallet" approach. Since so many things can cause a p0300 code, I am looking for advice on where to go from here. I realize 90 percent of the time it is spark plugs/wires....but this does not seem to be the case. These are the only things I added, aside from the headers themselves...so you can see my confusion. I ordered the o2 extensions, so I re-used my stock o2's which never gave me a code or a problem prior to this install. Just going down the list of possibilities...
One other thing-- do these engines seem to run a lot "hotter" with the headers installed? I'm not talking what the dummy gauge is saying (It never goes past 200, I also put a new 160 T-stat in upon header install)-- but when I open my hood...it seems the car really is HOT and stays hot for up to an hour or so after I drive (And I'm only making 15-20 minute drives). Part of me probably just notices it now because "I"m there", but another part of me begins to think maybe something is wrong.
Anyway, sorry for the novel guys-- I can't stand looking at this car as being a paperweight sitting in my driveway-- after 10 years of wanting to do this and buy one of these cars. Pretty disappointing, the car was fine before install--- she RUNS PERFECT now and pulls like a BEAST, but the code gets me very nervous (As in, I don't want to blow my engine so I won't risk driving it --LOL) I just thank myself that I have a daily driver in my truck, otherwise I would be S.O.L. My friend who installed this has been very open to fixing it and it's not like he's charging me anything to bring it back and re-do things. I am just trying to get an idea of what I can do and get some knowledge of this issue to figure out what the hell is going on. Process of elimination, and who better to ask than the FBODY COMMUNITY?!
Thanks for any input,
Kenny
Kenny
