Fueling & Injection - LS7 Intake and Throttlebody on 1998 Trans Am
Black LS1 T/A
08-12-2012, 03:19 PM
So ... what do I have to do (conversion kit, etc, if anything) to make a 90mm throttlebody work with the linkage on my 1998 Trans Am? Anyone know?
I have the LS7 Heads and Intake, Short LS7 Injectors, adaptors for the fuel rails, etc.
Thanks in advance!
ringram
08-12-2012, 04:36 PM
Get a cable throttle for it.
Job done.
Black LS1 T/A
08-12-2012, 05:30 PM
Job done.
Sorry to sound dense ... I already have a cable that came with car. Do you mean a cable that comes with a Corvette 90mm Throttle Body?
And I'm not really sure what you mean by a "cable throttle".
I also dug this link up up:
http://ls1tech.com/forums/generation-iv-external-engine/1438920-ls7-throttle-cable-bracket.html
Lonnies Performance
08-12-2012, 08:41 PM
The Corvettes are electronic, not cable driven.
If you get an aftermarket throttle body with cable drive, you are good.
You will need a special cable bracket for the LS7 intake as it does not have one on it.
fastcars95
03-27-2013, 12:14 AM
Does anyone have a part number for this bracket. I need to order a bracket to use a cable throttle body on a LS7 intake
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
