Can you delete stock pressure regulator?
Old 08-12-2012, 05:39 PM
383lt1ta's Avatar
Default Can you delete stock pressure regulator?
I am running an inline fuel pump with -6 line to inline fuel pressure regulator, then to the stock rails. My question is what to do with the stock regulator? Can you gut it or is there a plug? Thanks for the advice.
Old 08-12-2012, 08:02 PM
MUSTANGBRKR02's Avatar
Gut it.
Old 08-12-2012, 08:05 PM
JUSTINSWS6's Avatar
Just did mine today gut it i made a return system with a fuel pressure regulator by the rails
Old 08-12-2012, 08:38 PM
383lt1ta's Avatar
Is there anything particular I need or look out for when I gut it. Thanks, again
Old 09-06-2012, 12:55 AM
HRHohio's Avatar
Could you post some pics of how you did your setup? What fuel pressure regulator did you go with?
Thanks!
Old 09-06-2012, 07:53 AM
Ollie8974's Avatar
Removing the in tank fuel pressure regulator.
remove the spring clip holding the regulator in the module.
Attached Thumbnails Can you delete stock pressure regulator?-img_1009croped.jpg   Can you delete stock pressure regulator?-img_1012croped.jpg   Can you delete stock pressure regulator?-img_1010croped.jpg
Old 09-06-2012, 09:01 PM
bayer-z28's Avatar
I put my build pics in here.
https://ls1tech.com/forums/fueling-i...tem-build.html
Quick Reply: Can you delete stock pressure regulator?
