e brake loose after shifter install
Old 08-14-2012, 03:09 PM
Beastmode89's Avatar
Default e brake loose after shifter install
Nevermind, solution was so easy that I feel stupid.
Old 08-14-2012, 05:25 PM
Save the manuals!
wssix99's Avatar
Originally Posted by Beastmode89
That of course required me to deactivate the e brake and remove the console.
Huh? What exactly did you do to "deactivate" the parking brake? You should be able to get the console off by just pulling the stick up all the way.
Old 08-14-2012, 10:19 PM
trans_am7935's Avatar
yes, please explain this. there is only 2 screws that hold the ebrake lever to the body. need more explanation. unless you unhooked one of the wheels. if one of the wheels are unhooked it will cause symptoms just like this
