PCM or opti problem
Old 08-15-2012, 08:46 PM
transamguy1's Avatar
Default PCM or opti problem
Hey guys i have a 94 trans am lt1 and i am having a hell of a time with it.
The car cranks put doesnt start. I took the cap off the opti and i put cylinder 1tdc and the rotor doesnt point to wear it did before. Could the timing skip causing it to do this? The coil gets spark and so do the plugs. Also when i plug in my scanner to the obd1 port, it says that the vehicle is not responding. A buddy of mine thinks there is no power going to the PCM. Much help would be appreciated. Thanks guys
