Pontiac Firebird 1967-2002 - differential noise on 1999 trans am
17-Ws6-rick
08-16-2012, 11:20 PM
my differential is making a noise, my car doesnt have traction control and i have a replacement rear end that does have traction control is their anything i can do to put it on my car with out the traction control or fix my differential?
brendo389
08-17-2012, 12:22 AM
What is the noise? If it's whining under deceleration then the problem is likely a pinion bearing that has gone, but it can be anything really.
17-Ws6-rick
08-17-2012, 10:47 AM
yes it is a whining noise, what would i need to fix?
Paul Bell
08-17-2012, 06:00 PM
The direct answer to your question is no, here's why:
A car without traction control has three channel ABS with the sensor in the diff.
A car with traction control has four channel ABS with sensors at both rear wheels.
The brake lines are different also.
17-Ws6-rick
08-17-2012, 11:52 PM
what differential can i switch it to? which one is compatible with my car and has no traction control?
Paul Bell
08-18-2012, 06:28 AM
You need to find a three channel rear and swap it in. It'll have an electrical plug in the top of the housing.
You'll also need to match your ratio.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
