Multimedia Exchange - Jake99s Turbo 4.8 VS H/C/I LQ4 in a Z28
LS1FREEK
08-18-2012, 01:01 PM
Jakes truck is a 99 2wd RCSB Silverado and has a 150k mile '99 stock bottom end/heads 4.8, Isky triple 12 cam, ARP studs, MLS LS1 head gaskets, home built front mount Magnum 76mm turbo system, 4L80e w/shift kit and an Edge 3200 9.5" stall, 3.73 gears and 30" M/T drag radials. He was on 19#s of boost, 10.1 AFR, and 14 degrees timing.
The Z28 has a stock bottom end LQ4, PRC 215 heads, 233/239 cam, LS6 intake, Edge 4k stall, 3.42 gears and 315 Nitto NT555 tires.
First run Jake spins hard, second run, not so much lol
Jakes Turbo 4.8 vs Tavos Heads Cam LQ4 Camaro - YouTube
Jakes Turbo 4.8 vs Tavos LQ4 round 2 - YouTube
chrysler kid
08-19-2012, 10:36 AM
Videos are too dark. Time to get a go pro
