Generation IV Internal Engine - LS 3 Cam help?
View Full Version : LS 3 Cam help?
DubNova
08-19-2012, 03:50 PM
Hey guys, I have a 67 nova, LS3, long tube 1 7/8" headers, 3 inch exh,T56 Mag trans, 3:70 gear car weights in around 3000 pounds. I would like to replace the stock GMPP LS3 cam with something that got a little lope. I drive the car a lot and I don't want to fool with low speed surge or parking lot speed issues. I would like to have some more bottom end and mid range. Setting at a red light with the AC on full blast is a major issue! :nod: Any ideas? Thanks.....
DubNova
08-20-2012, 06:45 AM
Anybody?
forcd ind
08-20-2012, 07:57 AM
i have some stock LS3 heads, blue springs-the cam i am using is .580/.590 lift
should i upgrade to like PP's kit, something like .650 lift springs-are the retainers or locks built to allow more lift, installed spring height-thanks
forcd ind
08-20-2012, 07:58 AM
whoops, sorry, thought i was making a new post-had a brain fart
DubNova
09-22-2012, 06:58 PM
Bump?
1989GTA
09-22-2012, 08:49 PM
I would say something around 214 in the intake side and maybe 218 or so on the exhaust side. Probably a 113 LSA. Here is a link to a ton of Comp Cam lobes. You will have to scroll down some. Maybe give Texas Speed and Performance a call. Also for best performance with a cam change you should get a new tune. By the way you would be surprised on large you can go on a camshaft and meet your goals with a good tune.
http://texas-speed.com/p-161-comp-cams-custom-grind-lsx-camshaft.aspx
