need help Inline Filter ASAP
Old 08-20-2012, 09:39 PM
19trans_am98's Avatar
Default need help Inline Filter ASAP
looking for a -12an inline fuel filter that will support enough fuel flow for 1000hp at the wheels....needs to be 40 micron or smaller and stainless or compatible with e85...thanks
Old 08-21-2012, 11:52 AM
ZL1Killa's Avatar
uuhhh... aeromotive?
Old 08-21-2012, 06:35 PM
didnt see one....only paper...needs to go between pump and fuel rails
Old 08-21-2012, 07:41 PM
ZL1Killa's Avatar
they make one, when you look at their website and you look under fuel filter, it gives replacement elements, HOWEVER, they do SELL inline fuel filters as I have one, there website is NOT working worth a crap right now, all ERROR 404...just call them
the unit I'm using is http://aeromotiveinc.com/products-pa...d-fuel-filter/ had to look up my part number and then search their site for it.
or NastyN8 or Lonnies Performance.
Old 08-22-2012, 06:00 PM
stevieturbo's Avatar
10 and 40 micron are usually paper. Stainless mesh simply doesnt go down that small.
And Aeromotive make filters that will easily support that power.
Paper is fine between pump and rails. Dont use paper before the pump though ( although that's largely because in a gravity fed situation they wont flow enough )
Old 08-26-2012, 07:44 PM
found one http://www.summitracing.com/parts/SOF-200-201412/
Old 08-27-2012, 04:49 AM
Good find, they make some big flowing units !
Quick Reply: need help Inline Filter ASAP
