Rocker Arm ?'s for Stock Cam
I have searched and I cant seem to find a proper answer. When I do a search on say Comp Cams or Crane Cams I see specific Rocker Arms for LT1 Engines or say 88-97 engines but when I see people recommend a part number I see that they are suggesting standard SBC Part numbers that are not specific to the LT1 based engines.
Can someone give an explanation on what the differences are between an LT1 based Rocker Arm and a Standard SBC Rocker Arm and what is required to run a SBC Rocker Arm on an LT1 Engine?
I have two sets of SBC 1.6 Ratio Roller Rockers already and want to know if I can run them on my LT1. If so, what modifications will I need to make? I want to run better springs and I might as well run some roller rockers while I am in there. I have no intention of changing the stock cam so if you can recommend some good springs for either 1.6 if I can use my current Small Block Rockers or possibly 1.7 Scorpions if I have to buy new.
Joe
Joe
