1988 chevy pickup with supercharger
Year: 1988
Make: Chevrolet
Model: C/K 1500
Price: $11500
Mileage: 55000
Private or Dealer Listing: Private Listing
Location (State): TX
Color: Beige
Transmission: Automatic
Drivetrain: Rear Wheel Drive
Bel tech drop kit (springs, spindles, hangers) 3/4 Bilstein Shocks Addco Anti-Sway bars Caltrac Rear Traction Bars Billet Centerline"s Front 17x9.5 Rear 17x11 Michelin Sport Pilots Front 285x45 Rear 335x35 Auburn Posi- unit 3:42 (8.5") Corvette 700-R4 (B&M & Fairbanks) Tran Cooler Brass 4- core Radiator (New- w/ oil cooler) Hooker Super Comp. 1 3/4( Ceramic coater inside/ out) hearers Dual 3" exhaust w/ H-pipe & dual Flow Masters Dual 4" cat. convs. Bowtie 4- Bolt Siamesed Block (HEB Assembly) Callies 3.75 Stroke Forged Crank crower Rods 5.7 Costom J&E Pistons 8/1 Arp Fasteners- studs on main caps & Cyl. Heads 223 camshaft Comp cams roller- hydraulic lifters Dart Aluminum Heads (Prof. Prep)I208 E162 (300t@550) Crane Value springs Comp. cam pushrods & guide Plates Crane Gold Self - Align Roller Rockers Cyl. Heads Are O-Ringed / Recewer Grove For gaskets Edel Brock Intake Edel Brock Water Pump Crane Double Roller Timing set Tci Dampener (double -keyed) Big Block TBI unit MSD Ignition Jacobs Boost Controller Whipple SuperCharger upgraded from 1.5 to 2.2 Compassor Boost Gauge A/F Ratio Meter NOS PowerShot System 10lb Bottle W/Heater &Blanket SS Cluster W Extended Speedo and tach Ram Air hood GM Security System Pioneer Premier PIR recewer 7 spkr System (Infinity) 10" sub Rock ford 2- Rock ford Amps (600A5/ 250A2) 12 DIsc. Pioneer CD
Also have a matching set of rear rims with drag radials. Call for info. And pic.8324889889
