Need a 15" Black wheel for Black car that IS NOT a skinny. What are my options?
Old 08-26-2012, 06:24 PM
Hot Karl's Avatar
Default Need a 15" Black wheel for Black car that IS NOT a skinny. What are my options?
Well I've been looking to get 15s all around for my car. For the rear, I plan on going with a 15x10. Since this car is mostly driven on the street, I don't want skinnies for that. Yes I realize it helps with weight transfer, and times at the track, but because its mostly driven on the street, I wanted it to be configured more for that. It's not a DD, more of a weekend warrior so it will only be out during good weather. What are the options for wheels that aren't skinnies with the criteria I've listed? I had been looking at darkstars, but the only option appears to be either skinnies or 15x10. I'd like something with a similar 5 spoke style.
Old 08-26-2012, 09:10 PM
chrysler kid's Avatar
15 inch wheels will not clear the front caliper. You would need to convert to a set of drag brakes and even then they may not clear the caliper
Old 08-26-2012, 10:22 PM
Hot Karl's Avatar
If a 15 doesn't clear, how are so many people running 15" skinnies on the front? I'm not necessarily doubting what you say, just trying to find out what I'm missing.
Old 08-26-2012, 11:39 PM
StraightTimeStirrups's Avatar
It is my understanding that Skinnies will fit with spacers and grinding. I havent seen anyone running a wider then a 15x4" 15" Rim. There maybe someone but I havent seen it yet.
Joe
Old 08-26-2012, 11:45 PM
Default Street Miles with Mickey Thompson 26x4.5x15 Front Tires
I am curious to know how many street miles you can get out of set of MT Front Tires with the various models they have.
In addition, is there a problem of running Bias Ply up front and Drag Radials in the back? I know they say not to mix the two but I dont know if they mean on the same axle or Front to rear? I have heard its OK if not on the same axle.
Joe
PS. I have some 27.5x4.5-15s that I would like to run but they just dont seem to fit. I have seen some guys run them but they havent said what mods they have done to make them fit.
Quick Reply: Need a 15" Black wheel for Black car that IS NOT a skinny. What are my options?
