what injector with fast 92 intake
can you use any style injector with a fast 92 intake,i have ford red tops and they are the fat style injector,not sure if they are seated down far enough,here is a pic,
i believe you have a 14mm top O-ring and the same bottom O-ring.
as long as you have an injector with an O-ring that fits nicely of 14mm you are good. you will want to check your height, I can't remember what that is.
if you ever buy different injectors be wary of HEIGHT and your fuel rail.
Just recently I had the fitting/piece that is in the intake that the bolts thread into that hold the fuel rail down pulled out. I got the bolt off of it, and then took some JB weld (small amount) and pushed it back down in the hole on the intake. Let it set overnight and then finish installing and it won't come out.
