Figuring compression........HOW.......is there a calculator?
Old 09-06-2012, 08:08 PM
LS6427's Avatar
Default Figuring compression........HOW.......is there a calculator?
I want 10:1 cr out of my 390ci.
I know the crank is 3.825", bore is 4.030", rods are 6.125", head chambers are 65cc.
What piston?
((yes, I'd ask my builder, but he's closed....LOL))
Thanks.
Old 09-06-2012, 09:23 PM
Stumped1215's Avatar
You need piston cc, deck height, and head gasket thickness
Old 09-06-2012, 09:31 PM
LS6427's Avatar
I;m trying to figure which piston I need.....
So .051 gasket thickness....LS9 gaslets.
Deck height I guess is whatever a new GenIII LQ9 block is.......
*****and...I think 10.5:1 cr is what I want. As I'll be using E85 with 18psi.*****
Old 09-06-2012, 09:49 PM
http://www.wallaceracing.com/cr_test2.php
I'm getting about 8cc dish with the piston .008 above the deck
Old 09-06-2012, 10:48 PM
LS6427's Avatar
What did you use for deck height?
What for valve relief/dome? Isn't this what I'm looking for to choose the proper -cc piston?
Old 09-06-2012, 11:22 PM
ok -.008 deck height is the piston sticking up out of the hole 8 thousands which should be fairly close using shelf parts, but this makes a big difference on compression so it really should be checked before the heads go on.
4.030 bore
3.825 stroke
65cc head
10cc dish
.051 gasket
4.060 gasket size
-.008 deck
exactly 10.5:1
Old 09-07-2012, 12:39 AM
LS6427's Avatar
4.030 bore
3.825 stroke
65cc head
10cc dish
.051 gasket
4.060 gasket size
-.008 deck
exactly 10.5:1
Ok, thanks. I guess the only change would be 4.100 gasket size. LS9 gasket.
Quick Reply: Figuring compression........HOW.......is there a calculator?
